Mobil1 0w-20, 9884 Miles, 2003 Ford Focus
N/A
Hi everybody, Looks like 9,884 miles with M1 0w-20 isn't a good fit for my 2003 Ford Focus. Iron climbed dramatically higher. So, either my car is starting to wear in a bad way, or this oil isn't a good fit. The oil was in the car for about 9 or 10 months. The oil filter was a Wix. BTW, the previous numbers are from Amsoil 0w-20. Cheers, Bryan Blackstone Comments: As you run more miles on the oil, most metals should stay about the same. They will increase a little, but not much. The one exception is iron, which increases directly with miles on the oil. That's the reason that iron went up in your Focus. If you're comfortable with iron, you can stick with 10,000 or so miles on the oil. If it makes you nervous, drop back to 7500 miles next time. The TBN read 2.1, getting low but still showing some active additive remaining. Insolubles show good oil filtration and not a lot of oxidation. Check back to monitor iron.
 Code:
ELEMENTS IN PARTS PER MILLION:
                     M1 0w20         Ams 0w-20
MI/HR on Oil:        9,884           6,546
MI/HR on Unit:       79,884          58,065
Sample Date:         5/23/09         9/26/07
Make Up Oil Added:   0 qts           0 qts
                     My Car                    Unit* Averages
Aluminum             4               2           3
Chromium             1               0           1
Iron                 32              7           20
Copper               3               2           3
Lead                 1               0           1
Tin                  0               0           0
Molybdenum           82              4           43
Nickel               1               0           1
Manganese            0               0           0
Silver               0               0           0
Titanium             0               0           0
Potassium            2               1           2
Boron                34              6           20
Silicon              13              11          12
Sodium               6               8           7
Calcium              2088            3229        2659
Magnesium            11              9           10
Phosphorus           614             552         583
Zinc                 702             643         673
Barium               0               0           0
                     My Car                      Values Should Be
SUS Viscosity @210F  52.5            53.5        46-59
cSt Viscosity @100C  8.03            8.34        6.0-10.2
Flashpoint in F      385             405         >385
Fuel %               TR              <0.5        <2.0
Antifreeze %         0.0             0.0         0.0
Water %              0.0             0.0         <0.1
Insolubles %         0.3             0.2         <0.6
TBN                  2.1             4.7
Canada
Wow. M1 did a LOT worse compared to the ASM. Sad to see. What did you replace the M1 with?
ffxfina3
N/A
Replaced with M1 because that is what I had. But I'm thinking I'm probably going to change it at 5K Miles or so, and then go with PP 5w-20 at continued 5K intervals. -Bryan
Illinois
That's avery good report for the miles on the oil. 1/3rd more miles than the Amsoil. No problems running that oil.
Buffalo, NY
With over 3000 more miles on it...
Milwaukee, WI
What mileage were the universal averages for this engine based on? Without that, it's hard to say if the iron is high or low. All you have to compare it to is one other UOA. If the universal is 5000 miles, then 32 is actually pretty good.
midwest
You should be fine with a 7500 run. Except for the iron, that was a good UOA for 9884 miles OCI.
ffxfina3
N/A
Oops!!!. Thanks bepperb. I just caught an important mistake in the numbers I put up. What I am listing as the Universal Averages is is really the Unit Averages. Here are real Universal Averages. Can an administrator/moderator please edit my post so that it reads Unit Averages? Sorry guys.
 Code:
                     Universal Averages
Aluminum             3
Chromium             1
Iron                 12
Copper               4
Lead                 1
Tin                  1
Molybdenum           65
Nickel               0
Manganese            0
Silver               0
Titanium             0
Potassium            1
Boron                63
Silicon              13
Sodium               14
Calcium              2342
Magnesium            103
Phosphorus           706
Zinc                 860
Barium               1
PA
Those oils appear to have both performed admirably and similarly. Iron spike like that doesn't mean much. The Universal average is 20....based upon what mileage? You are probably seeing about average wear with Iron. Further, the oil was run longer than AMSOIL but had almost identical viscosity and a relevantly lower TBN. Remember that low-level dissolved metals in UOAs are not good indicators of engine wear. The oil proved that it held up, though it was at the end of it's life.
ffxfina3
N/A
Just got off the phone with Blackstone. The Universal averages is based on 5,900 Miles. -Bryan
ctc
VA
If I were you, and I'm not :), I would leave the current M1 in for 7500 and do another UOA.
PA
So your iron showing was actually at or below universal averages for this engine :)
ctc
VA
He had incorrectly labeled the unit avg as Universal Avg. The correct Universal Avg for iron was 12 at 5900 mi.
ffxfina3
N/A
Thanks everybody who has responded. When I spoke further with Blackstone, they told me that theoretically, I could assume that with iron at 12 PPM at 5900 miles (universal avg), that the average would be 24 PPM at 12000 miles. This is unfortunately my first ever run of M1 0w-20 in this car, so I don't have any real idea whether iron was high on the entire oil run, or if it jumped in the last few thousand miles. I'll have to ponder on this for a little while and make a decision on M1 vs. PP. Cheers, Bryan
ffxfina3
N/A
 Originally Posted By: Throckmorton
What kind of driving do you do?
This is my wife's car. We live in the country (but not on a gravel road). She does a lot of in town driving, but getting to town is at least a 8 mile drive. We also have a block heater installed in the car which we used many times over the winter. This car is also used for family excursions/vacations etc. I'd say that she puts about 900-1000 miles a month on the car. -Bryan
NJ
32ppm of Fe is low. It's a bit high compared to ASM, but well below 150ppm alert level.
