Oh hell for that I'm better off sticking with Kirkland signature!!! LMAOMobil 1 has PAO in the mix and possibly other base oils like alkylated naphthalene that don't show on the SDS, Mobil Full Syn is like Supertech or other store brand synthetics it's a basic store brand synthetic.
If it's the same price use either, but unless you're getting it at Autozone clearance prices, I see no reason to buy Mobil Synthetic over store brands that are cheaper.Oh hell for that I'm better off sticking with Kirkland signature!!! LMAO
I assume that's the autozone clearance, typically Mobil Full syn is more expensive than the store brand.Kirklands up to $15 jug here, I got 2 of the Mobil for $12 each.
I'm with ya...BUT for $2 more for 5 quart jug, I'd feel better with Super Tech. Not staying its better or worse; based off so many UOA's here gives me added comfort. YMMVKirklands up to $15 jug here, I got 2 of the Mobil for $12 each.
I spoke with Warren distribution earlier today, I believe it was Ron from technical support said, Amazon basics and Kirkland signature was pretty much the same as Super tech 20,000 MI oil I don't know if that's true or false.. if you've looked at a virgin oil analysis you may know.. if you know just let me know..PQIA did MAG1 and Mobil full syn not too long ago, the Mag1(same as Supertech, Meijer, Kirkland, etc) has more boron and less moly, while the Mobil has more moly and less boron, they look pretty similar otherwise, not much of a surprise, since Warren gets base oil from Exxon Mobil and they probably use a basic Dexos compliant lubricant template from Mobil.
Yes, Amazon, Kirkland, Supertech, Warren's own MAG1 brand are all the same oil with a different private label to my knowledge.I spoke with Warren distribution earlier today, I believe it was Ron from technical support said, Amazon basics and Kirkland signature was pretty much the same as Super tech 20,000 MI oil I don't know if that's true or false.. if you've looked at a virgin oil analysis you may know.. if you know just let me know..
What about that 20K Super tech?It all comes out of the same blender.
Blenders produce a lot of different blends.What about that 20K Super tech?
