Mobil Spartan EP 220
Could this oil be used in automotive or tractor applications? Transfer case, transmissions, axles etc? I have access to quite a bit of it but haven’t found really info on its compatibly.
Millbrae, CA
Its a EP-4 industrial gear oil about half SP treat as regular Hypoid oil. It would be fine if vis is right a 220 is a 90wt.
NOT for hypoid axles but manual trans and transfer case IF they require a SP oil. Not strong enough for auto axles.
Tractors will be fine in axles BUT may require and anti squak additive for chlutch plates.
