Several UOAs from the Ram EcoDiesel
Thanks in advance!
Thanks in advance!
There was a short OCI between with a blend of oils.I've never done Wix or other Blackstone type reports so not really familiar with reading the metrics but do the time on unit/time on oil numbers add up for the last submission?
Gasket maker from replacing the oil pan. Good question!What's up with the coolant?
Well, as you can see that is snow in the bottom pic. ❄You live in California, how frigid does it really get there? Be kind to your engine, that Delvac Extreme full synthetic 15W-40 is great oil and gave you good results. If it aint broke, don't fix it.
Yes, the OEM pan holds 10.5qts. The aftermarket AFE pan brings ot to an even 12qts. I agree, 5k OCI may be overkill but I do this for a hobby and for fun. I feel most comfortable with limiting the OCI to 5k.The other thing I noticed was a 12 quart sump listed. Man, that seems like a lot of oil to be dumping every 4-5k for a 3 liter engine.
I'm going to use Delo 600 ADF and see if that helps.His soot is ~ 1%, that seems high especially when you consider it's 12 qts and only 5K miles on the oil. This is also CARB diesel which burns pretty clean. I think the updated tune FCA gave the EcoD after the emissions recall isn't that great and it burns dirty. I'd change it early too.
OP can probably cut his soot production by 50-75% by using a diesel fuel additive like Redline catalyst or TDR-FL
How would that help? Soot is from combustion, not the oil itself.I'm going to use Delo 600 ADF and see if that helps.
Can someone help me understand how my sample at 5700 miles with low wear metals, has a viscosity that is uncharacteristic of Delvac?
