Mobil Delvac 1 5W-40 94 ZX-11 1579 miles
Vermont
This is Mobil Delvac 1 with 4 ounces of Lube Control at the start, and with maybe .25 quarts of Rotella T synthetic as top up. This oil seemed to work great right up to the end, shifted nicer than an other oil I've tried. Lab is OAI.
code:
Miles on unit          34544
Miles on Oil           1579
Iron                   18
Chromium               1
Lead                   1
Copper                 6
Tin                    0
Aluminum               11
Nickel                 0
Silver                 0
Silicon                6
Boron                  55
Sodium                 5
Magnesium              468
Calcium                2375
Barium                 0
Phosphorus             1163
Zinc                   1400
Molybdenum             0
Titanium               0
Vanadium               0
Potassium              0
Fuel                   <1
[email protected]              11.72
Water                  0
Glycol                 NEG
TBN                    8.92
Oxid                   3.0
Nitr                   7.0
Even the mighty Delvac 1 gets chewed down to a 30wt in a motorcycle. Frankly, as long as it feels good and protects well, I don't care if it shears down a grade. I've even been toying with the idea of running GC when it gets cooler! Currently I am running the new Amsoil 10W-40 motorcycle oil which I plan to sample at 700 miles and 1500 miles.
Cedar Park, TX
iron and copper are pretty high for this few a miles on the oci. with Al of 11, i have to guess you are slipping the clutch a little every once in a while too. silicon of 6 means your air filter is doing pretty good too. when was the last time you changed the air filter? whose oil filter are you using?
nicrfe1370
Vermont
The oil filter is Kawasaki. I'm not sure about the air filter, but it is probably also a Kawasaki piece. I don't know when it was last changed, I bought the motorcycle this May and haven't changed it yet (though I will probably do so in the off season). My basic practicehen driving any manaully shifted transmission is to slip the clutch as llittle as possible, but with my Kawasaki I might slip it a bit more than is necessary.
