Background: I bought a new GMC Sierra Denali Crewcab with the 345hp 6.0L and did the first oil change at 1,800 miles and wanted to use a dyno oil first before going to Mobil 1 at around 5k miles. I am not impressed with Mobil 5000...especially when Blackstone recommends 3,100 mile intervals! I had much higher TBN with Mobil 1 in my Jeep 4.0 with nearly 7,000 miles on that oil sample. I did not expect Clean 5000 to match M1, but I would have hoped for a better showing than this. Perhaps it is not all the oil, but the newness of the engine.
What do the BITOG experts think?
Oil used: Mobil Clean 5000 5W/30
Miles on oil: 3,078 - no make up oil needed.
Blackstone comments: "You are able to see most anything come up high in the first or second oil sample from an engine, so there is nothing terribly startling about any of the data in this report. This type of oil uses sodium as an additive though, so we've put a "?" in the anti-freeze slot. That is because if there was a little anti-freeze in this oil we couldn't see it. Our ID for anti-freeze is sodium. Mobil 1 doesn't use it so we should be able to tell you more in your next Mobil 1 sample. Silicon and copper are high due to the newness of the engine. The TBN was 2.7, still okay. Stay at 3,100 miles use next sample.
Test results:
aluminum - 3
chromium - 0
iron - 18
copper - 138
lead - 5
tin - 0
moly - 109
nickel - 0
maganese - 3
silver - 0
titanium - 0
potassium - 2
boron - 28
silicon - 42
sodium - 223
calcium - 1566
magnesium - 9
phosporus - 568
zinc - 681
barium -0
Sus Viscosity @ 210degrees = 55.4
flashpoint = 390
fuel = antifreeze = ? due to oil used
water= 0
insolubles= 0.2
TBN = 2.7
Test results:
aluminum - 3
chromium - 0
iron - 18
copper - 138
lead - 5
tin - 0
moly - 109
nickel - 0
maganese - 3
silver - 0
titanium - 0
potassium - 2
boron - 28
silicon - 42
sodium - 223
calcium - 1566
magnesium - 9
phosporus - 568
zinc - 681
barium -0
flashpoint = 390
water= 0
insolubles= 0.2
TBN = 2.7
