quote:
Bill, in your post that initiated this thread you provide a link to a VOA that also indicates Na in Mobil 7500 ... and as George admitted a mistake was made in testing the viscosity of this oil, I'm not sure why you're now dissatisfied with Mobil.
Well, When I posted the Dec 9th post, the sample was run and then run again and verified that the sample was 40wt.
After I posted my "I'm not happy with Mobil" a day later the Visc is ok now...
I guess for me, when I change out my Mobil 7500 oil in the 2002 Silverado.. I'll spend the $$ and run a used oil analysis on it and lets see what I get.
I was not going to run a used oil analysis, but it's the only way I'd use up the rest of Mobil I have if it comes out ok.
If it comes out ok, then I'll use up the rest of it and then decide what to run in her truck. It's been on Mobil for the last 2 years.
I don't like Mobil 1 (I've run it now in 4 outfits and every one did better used oil analysis on Pennzoil or Castrol dino for the 4-5k I run OCI) but I do like Mobil 7500 and 5000 as I feel for the $$ (1.99 a quart for 7500 and .89 cents for 5000) it's a good oil.
Running $1.99 oil for 7500 miles is alot better than running $5 qt oil for the same.
I'll guess we will see...
Take care, Bill
