- Messages
- 421
- Location
- LUBBOCK, TX
Does anyone see a problem in using Mobil 1 5W-30 and changing it by the engine oil life monitor. Monitor usually shows about 4000 miles when it says to change the oil. I have been using an extended drain oil up till now with 6 months filter changes. I think if I use the oil life monitor system I will be changing oil about every 8 months. I think that doing the filter changes with the oil I'm using now verses changing with the monitor system I'll be getting fresh oil every 8 months. If you have to get under there to change the filter, you might as well change the oil anyway. Comments please.
[ December 25, 2002, 08:50 PM: Message edited by: westex39 ]
