Mobil 1 V-Twin 20W50, 1237 miles, 2004 Kawasaki ZZR250
OTTAWA, ON, CA
Most recent UOA is on the left; I included the others for comparison and I hope it doesn't mess up the formatting. I think I'm going to go for longer OCI's now, but still do an oil change during the winterizing process. I did not like cold start-up with this oil; shifting felt fine once warmed-up.
Another useless fact, the average fuel economy during each of the OCI's was from left to right 66.58, 66.51, 65.86 in U.S. M.P.G.
code:
Sample Date 26-AUG-2006 17-June-2006
Analysis Date 29-AUG-2006 20-June-2006 22-OCT-2005
Lab WEAR CHECK WEAR CHECK WEAR CHECK
Make Kawasaki
Model ZZR250
Year 2004
Engine 248cc L2
Miles 10862 9625 8329
Oil Brand Mobil Mobil Mobil
Oil Series M1 V-Twin M1 MX4T M1
Oil SAE J300 20W50 10W40 15W50
API SX SG/SH/MA SG/SH/MA SL
Miles on Oil 1237 1295 875
Months 2 7.8 1.4
Antimony Sb NR NR NR
Cadmium Cd NR NR NR
Vanadium V 0.1 0.1 0.2
Aluminum Al 7.8 8.8 6
Chromium Cr 0.4 0.6 0.5
Iron Fe 7.9 10 7.7
Copper Cu 1.9 3.4 4.7
Lead Pb 0.7 1.1 0
Tin Sn 0 0.5 0.6
Molybdenum Mo 70 71 83
Nickel 0 0 0
Manganese Mn 0.9 4.9 0.4
Silver Ag 0 0 0
Titanium Ti 0.1 0.1 0.1
Potassium K 0 0 0
Boron B 202 182 211
Silicon Si 4.7 5.8 5.3
Sodium Na 1.7 1.6 19
Calcium Ca 2063 2173 3166
Magnesium Mg 12 14 20
Phosporus P 1366 1436 1190
Zinc Zn 1385 1484 1334
Barium Ba 0 0.1 0.3
Sulfur 2801 2590 2405
cST @ 100 C 17.0 12.5 14.6
SUS @ 210 F NR NR NR
Flashpoint (F) NR NR NR
Fuel %
Antifreeze % NR NR NR
Water %
Insolubles % NR NR NR
Sulfation 51 56 61
Oxidation 48 63 71
Nitration 20 28 34
TBN NR NR NR
TAN NR 3.26 3.55
Ferrous Debris NR NR NR
Fuel Soot % NR NR NR
Glycol NEGATIVE NEGATIVE POSITIVE
ISO Code NR NR NR
Additives NONE NONE NONE
URL NR t=000079 t=000057
Notes Sample at next interval
Location Ottawa, ON, CAN
Air Filter Kawasaki OEM Kawasaki OEM Kawasaki OEM
Oil Filter FRAM CH6012 FRAM CH6012 FRAM CH6012
***Particle Count***
>2 micron NR NR NR
>5 micron NR NR NR
>10 micron NR NR NR
>15 micron NR NR NR
>25 micron NR NR NR
>50 micron NR NR NR
>100 micron NR NR NR
Same oil as the one above on the left. The samples were taken about 5 seconds apart, for some reason no viscosity testing was done. Different lab, Toromont-CAT results:
code:
Analysis Date 2-SEP-2006
Lab Toromont-CAT
Make Kawasaki
Model ZZR250
Year 2004
Engine 248cc L2
Miles 10862
Oil Brand Mobil
Oil SAE J300 20W50
API SX SG/SH/MA
Miles on Oil 1237
Months 2.3
Antimony Sb NR
Cadmium Cd NR
Vanadium V NR
Aluminum Al 6
Chromium Cr 0
Iron Fe 9
Copper Cu 1
Lead Pb 0
Tin Sn 0
Molybdenum Mo 67
Nickel 0
Manganese Mn NR
Silver Ag 0
Titanium Ti NR
Potassium K 1
Boron B 0
Silicon Si 3
Sodium Na 9
Calcium Ca NR
Magnesium Mg NR
Phosporus P NR
Zinc Zn 1025
Barium Ba NR
Sulfur NR
cST @ 100 C NR
SUS @ 210 F NR
Flashpoint (F) NR
Fuel % NEGATIVE
Antifreeze % NEGATIVE
Water % NEGATIVE
Insolubles % NR
Sulfation NR
Oxidation NR
Nitration NR
TBN NR
TAN NR
Ferrous Debris NR
Fuel Soot % NR
Glycol NR
ISO Code NR
Additives NONE
URL
>2 micron NR
>5 micron NR
>10 micron NR
>15 micron NR
>25 micron NR
>50 micron NR
>100 micron NR
dont you just love it when the numbers from 2 labs do NOT match. i sure do.
also notice how mobil 1 15w50 did not hold its viscosity very well in less miles!
nice wear metals!
very nice mpg out of the baby ninja!
I think you'll like a 10W-40 better in this bike. I have a Ninja 500 and the shifting is very consistent and I have quick warm up times. Thick oil (especially on start up)concerns me in these engines as they rev so high all the time.
My mileage also ranges from 56-65 mpg, I would think you should be in the 70 range with a 10W-40 unless you ride it pinned all the time.
Same thoughts as MDV, 10w-40 is all you need.
xx-50 oils is getting pretty heavy for that light weight, free spinning motor. (Any bike motor for that matter, except 750+ air cooled twins.)
sunruh: Thanks for the comments. It makes me sort of laugh at UOA's after seeing the differences between the two labs
Especially when people fret over a difference of 5 ppm from one oil to the next etc.
mdv: 10W40 yielded 0.07 US MPG less than 20W50. I think that could be considered statistically insignificant. This is going to sound odd: from what I've read online EX500's in the US average 50-60 US MPG. EX250's in the US average 55-70 US MPG. For mine in Canada this season it's been 62.73-70.86 US MPG. I've been to the US once with my car, and the fuel there yielded much better efficiency than the fuel up here, could it be something in our Canadian fuel ??? Or maybe I just ride with it pinned all the time
