Most recent UOA is on the left; I included the others for comparison and I hope it doesn't mess up the formatting. I think I'm going to go for longer OCI's now, but still do an oil change during the winterizing process. I did not like cold start-up with this oil; shifting felt fine once warmed-up.
Another useless fact, the average fuel economy during each of the OCI's was from left to right 66.58, 66.51, 65.86 in U.S. M.P.G.
code:Sample Date 26-AUG-2006 17-June-2006 Analysis Date 29-AUG-2006 20-June-2006 22-OCT-2005 Lab WEAR CHECK WEAR CHECK WEAR CHECK Make Kawasaki Model ZZR250 Year 2004 Engine 248cc L2 Miles 10862 9625 8329 Oil Brand Mobil Mobil Mobil Oil Series M1 V-Twin M1 MX4T M1 Oil SAE J300 20W50 10W40 15W50 API SX SG/SH/MA SG/SH/MA SL Miles on Oil 1237 1295 875 Months 2 7.8 1.4 Antimony Sb NR NR NR Cadmium Cd NR NR NR Vanadium V 0.1 0.1 0.2 Aluminum Al 7.8 8.8 6 Chromium Cr 0.4 0.6 0.5 Iron Fe 7.9 10 7.7 Copper Cu 1.9 3.4 4.7 Lead Pb 0.7 1.1 0 Tin Sn 0 0.5 0.6 Molybdenum Mo 70 71 83 Nickel 0 0 0 Manganese Mn 0.9 4.9 0.4 Silver Ag 0 0 0 Titanium Ti 0.1 0.1 0.1 Potassium K 0 0 0 Boron B 202 182 211 Silicon Si 4.7 5.8 5.3 Sodium Na 1.7 1.6 19 Calcium Ca 2063 2173 3166 Magnesium Mg 12 14 20 Phosporus P 1366 1436 1190 Zinc Zn 1385 1484 1334 Barium Ba 0 0.1 0.3 Sulfur 2801 2590 2405 cST @ 100 C 17.0 12.5 14.6 SUS @ 210 F NR NR NR Flashpoint (F) NR NR NR Fuel % <2.0 0 <2.0 Antifreeze % NR NR NR Water % <0.1 <0.1 <0.1 Insolubles % NR NR NR Sulfation 51 56 61 Oxidation 48 63 71 Nitration 20 28 34 TBN NR NR NR TAN NR 3.26 3.55 Ferrous Debris NR NR NR Fuel Soot % NR NR NR Glycol NEGATIVE NEGATIVE POSITIVE ISO Code NR NR NR Additives NONE NONE NONE URL NR t=000079 t=000057 Notes Sample at next interval Location Ottawa, ON, CAN Air Filter Kawasaki OEM Kawasaki OEM Kawasaki OEM Oil Filter FRAM CH6012 FRAM CH6012 FRAM CH6012 ***Particle Count*** >2 micron NR NR NR >5 micron NR NR NR >10 micron NR NR NR >15 micron NR NR NR >25 micron NR NR NR >50 micron NR NR NR >100 micron NR NR NR
