This is good news since the "Truck and SUV" oil is the same price as M1. Delvac1 normally cost more than M1 and is hard to find.
Thanks heyjay
Thanks heyjay
They don't even list the HTHS...quote:
Unfortunately, Exxon-Mobil is continuing its "new" tradition of not publishing detailed oil test results such as MRV BPT or any MRV values at all.
Following ASTM D445 test procedures, Exxon Mobil lists the kinematic viscosity at 100 C as 14.8 cSt.quote:
Originally posted by moribundman:
I'd be interested in the viscosity at 100, 120, 140, and 160 degree C.
Thanks!quote:
Originally posted by Quick_lude:
Heaven forbid that the consumer had too much info..
Jerry, try calling these guys at www.noco.com/canada and see if they can get you the 0w30 or 5w40.
quote:
Mobil Delvac 1
Typical Characteristics
Product Number 44111-3
SAE Grade 5W-40
Gravity, API 32.3
Pour Point, °C (°F) -54 (-65)
Flash Point, ASTM D 92, °C (°F) 230 (446)
Viscosity
cSt at 40° C
cSt at 100° C
SUS at 100° F
SUS at 210° F
95.0
15.0
481
79
Cranking Viscosity,
cP at -25° C
3,200
Pumping Viscosity,
cP at -35° C
20,500
Borderline Pumping Temperature, °C -44
HT/HS, cP at 150° C 4.1
Viscosity Index 167
Sulfated Ash, wt % 1.3
TBN, ASTM D 2896 11
Color, ASTM D 1500 5
Dynamic viscosity is N.s/m^2 = 1 Poise, so 1 mPa.s = (0.001) Pa.s = = 1 cP or 1 centipoise, as the HTHS is always listed at the cP viscosity at 150 C.quote:
For example, Mobil Delvac 1300 Super 15W-40 is rated for HTHS as 4.3 mPa s @ 150 C. The designation mPa s is comparable to cSt, so you could also state the HTHS as 4.3 cSt @ 150 C. comparable to cSt, so you could also state the HTHS as 4.3 cSt @ 150 C.
HT/HS is a measure of the oils ability to resist 'shearing' or viscosity reduction. The standard HT/HS test is at 1 million 'shears' per second at 250C.quote:
Originally posted by Buzzsaw:
What is HTHS? Thanks.
