- Messages
- 8
- Location
- United Kingdom
I live in the UK and have bought 20 litres of Mobil 1 Tri-Synth at a discount price not realising it was superceded by the Super-Synth formulation. I use this in a small Nissan daily driver with twin overhead cam, 4 valves per cylinder engine, that has 3k miles from new and has used this Tri-Synth from 1k miles and I change at 3k miles with Nissan filter. The grade is European formulation 0-40 and the weather temp range is say 20f to 90f. Is there enough difference in the Super-Synth to warrant not using my stock of Tri-Synth? Hopefully you will all say its OK to use the Tri-Synth!
Fabulous board, thank you, I have learned loads.
Roger
