Drug-abuse 'experts' often refer to pot as the 'gateway drug', as its ease of access for young people means it is the first drug they start on, before going on to 'harder stuff'. We've all heard that analogy.
Without being funny, in much the same way, I think of Mobil 1 as the 'gateway synthetic' - because of its wide pubicity, and ease of access, if someone is going to try a synthetic oil in their car, it will often be Mobil 1. Friends recommend it to them, they see an add, or they just keep seeing it on the shelves of stores. Some will be happy with it; and stick with using it faithfully, while others move on to 'harder stuff' - more expensive, exotic sythetic oils, like Motul, Neo, or RLI.
Was Mobil 1 your 'gateway' into synthetic oil use? Did you 'move on' from it? Tell your tale here!
