Just got my Blackstone lab results and was a bit nervous since this was my first oil analysis. The oil was in use for 4.5 months since the middle of October '02. The truck is driven 90% city/10% highway with alot of short trips. Anyway, here are the test results:
below and it will look just like you print it. example...
Aluminum: 3 4
Chromium: 2 2
Iron: 5 21
Copper: 7 13
now with code button
code:Any comments would be greatly appreciated! Thank you. I got an email from a lube specialist that was really concerned thinking that this analysis was bad due to the spacing when it was posted because the numbers were all jumbled together. To help from this, when trying to space the lines down like this, use the code buttonOil filter: Purolator Premium+ Air filter: OEM Isuzu Miles on oil 2972 Miles on unit 33642 Make up oil (I like to keep it to FULL mark) 0.4qt Sample Univ. Average Aluminum: 3 4 Chromium: 2 2 Iron: 5 21 Copper: 7 13 Lead: 0 1 Tin: 2 2 Molybdenum:61 32 Nickel: 0 0 Manganese:0 0 Silver: 0 0 Titanium: 0 0 Potassium: 1 1 Boron: 105 75 Silicon: 7 11 Sodium: 7 10 Calcium:2663 2252 Magnesium:59 270 Phosphorus:769 835 Zinc: 917 1046 Barium: 0 0 SUS Visc., 210F: 59.1 Flashpoint: 370F Fuel: less than 0.5% Antifreeze: 0.0% Water: 0.0% Insolubles: 0.3%
code:[ March 25, 2003, 06:20 PM: Message edited by: ED P. ]Aluminum: 3 4 Chromium: 2 2 Iron: 5 21 Copper: 7 13
