Mobil 1 Racing 4t or Valvoline 10w40 Motorcycle oi
TN
I wondering on how these two compare I know mobil 1 racing is the synthetic but it's 10 bucks a quart vs valvoline being around 4 bucks. What's your thoughts?
NY
Personally I would just skip both and go with motul 300v. And yes I have used both the Mobil and valvoline bike oils and the motul 300v is the ONLY oil to give my r6 smoother shifting, quieter engine, runs a bit cooler, and even better gas mileage. I recently went to Laconia running said motul and so glad I did and witnessed all benefits. I believe you do get what you pay for at least regarding motorcycle oil.
Cincinnati, OH
my yamaha fz6r has 4k mile oci's so im going to stick with the mobil. that should net and oil change once every two years. $30 in oil for two years of use is cheap enough for me.
Ca USA
If you're racing you want the oil with the least amount of drag to free up the most ponies... synthetics flow freer than dino because synthetics sport uniform molecules and that extra step process is why Mobil 1 cost more to produce...
Central IA
But if you are not racing and not doing extended OCI's then why bother with what creates the least drag on HP? Then I would just use what my motor likes best in a UOA. For instance Dino Valvoline VR1 in a Twin Cam Harley made for a better UOA than Syn 3.
Originally Posted By: jrustles
Mobil MX4T is likely ester based- is it the same as "Racing"? The Valv's is more than likely mineral.
It's no longer named Mobil 1 MX4T, it's Mobil 1 Racing 4T. No ester in it. It is a Group III+/IV/V blend: Mobil's proprietary VISOM (III+), PAO (IV), and Alkylated Naphthalene (V). The AN is the additive solubility agent. The blend ratios of course are not known.
Australia
That doesn't surprise me in the least. SYN 3 = genuine overrated and expensive. What an appalling waste of money.
Ca USA
If you're like me and I pay to God you're not... you ain't happy with loosing HP to oil drag... so its no bother to run synthetics namely 0-30... just think of the bother and the expense riders go to gain 3 to 4 HP by installing an after market exhaust systems with the corresponding Dyno runs and the remapping of the fuel in the ECU... comparative speaking switching to a freer flowing oil is relative cheap and easy HP...
Ontario, Canada
Thanks for the headsup! Suddenly less interested in it now. That's what happens when you try to give Mobil some credit.. Totally my fault. LOL
South Carolina
If you do some research you will find Valvoline 4 Stroke CONVENTIONAL motorcycle oil beats or better said is in the middle of the pack when it comes to engine wear, when compared against 8 or 10 synthetic motoroils in Amsoils own motorcycle oil test reports. Amsoil and Mobile one have a better wear number, yet Valvoline Conventional is better then or the same as all the other synthetics in the test. So its a no brainer, go with the $4.00 oil and change it on time or in half the time and you will be doing even better.
