Mobil 1 Peak Life 5W-50, BMW E39 540iA, 19935 km
Germany
Dear All, Please find below the results of the latest and the previous (Mobil 1 Peak Life 5W-50, BMW E39 540iA, 27262 km) oil analyses for my BMW. This time I had Blackstone performing the oil analysis, as I had been curious whether ordering a test kit and sending it to the USA would actually work?! I received the results one week after I took the sample to the post office. The measurements or results respectively seem to coincide with the results of the previous analyses although I am not quite sure whether the BN (Base Number, Oelcheck) and TBN (Total Base Number, Blackstone) measurements are interchangeable/comparable? I again used 100 % E85 fuel and added my favorite oil additives. smile What are your opinions? Philipp
Code:
REPORT #5:
  Subject   : Mobil 1 Peak Life 5W-50, BMW E39 540iA, 19935 km (oil), 147090 km (total)
  Machine   : M62B44TU (E39 540iA, YoC 2002)
  Oil       : Mobil 1 Peak Life 5W-50
  Additive  : Wynn's Oil Stop Leak (as sealant maintenance) (added several times over oil usage, 1 liter in total)
  Additive  : Liqui Moly Visco-Stabil (VI improver) (added several times over oil usage, 0.6 liter in total)
  Oil Usage : 5.5 month
  Comments  : [of the engineer performing the analysis]
    Universal averages show typical wear levels for this type of engine after
    about 8,800 km on the oil. You ran your oil much longer, putting nearly
    20,000 km on this fill. Your longer oil run will normally generate a lot
    more wear than average, so these levels are not bad considering the long
    run. If you'd like to see less metal in the oil you could try a shorter
    oil change, but if you are okay with these numbers then we'd say run
    20,000 km again. The oil handled the long interval well, with a strong
    TBN of 3.2. Insolubles are very low at a trace. No fuel/coolant found.
REPORT                          #5          #4          #3          #2          #1
                                CURRENT     PREVIOUS    PREVIOUS    PREVIOUS    PREVIOUS
LABORATORY                      BLACKSTONE  OELCHECK    OELCHECK    OELCHECK    OELCHECK
WEAR
Iron          Fe      mg/kg     33          38          27          17          15
Chromium      Cr      mg/kg     1           1           0           0           1
Tin           Sn      mg/kg     5           1           0           0           2
Aluminium     Al      mg/kg     10          12          6           3           3
Nickel        Ni      mg/kg     0           0           0           0           0
Copper        Cu      mg/kg     17          23          16          13          6
Lead          Pb      mg/kg     8           9           4           3           3
Manganese     Mn      mg/kg     1           2           1           -           1
Titanium      Ti      mg/kg     0           N.A.        N.A.        N.A.        N.A.
PQ-Index                  -     N.A.        < 25 (OK)   < 25 (OK)   26          < 25 (OK)
CONTAMINATION
Silicon        Si     mg/kg     4           7           10          10          15
Potassium       K     mg/kg     0           3           3           2           1
Sodium         Na     mg/kg     6           9           6           7           0
Silver         Ag     mg/kg     1           2           1           -           -
Water                     %       0.0         0.22      < 0.10 (OK) < 0.10 OK   < 0.10 (OK)
IR-Glykol / Antifreeze  -/%       0.0       negative    negative    negative    negative
Fuel                      %     < 0.50      < 0.30 (OK) < 0.30 (OK) < 0.30 (OK) < 0.30 (OK)
OIL CONDITION
Viscosity @  40°C     mm²/s     N.A.        95.68       111.26      110.95      80.50
Viscosity @ 100°C     mm²/s     13.63       14.57       17.12       16.90       13.43
Viscosity @ 210°F       SUS     72.6        N.A.        N.A.        N.A.        N.A.
Viscosity Index           -     N.A.        158         169         166         170
Oxidation              A/cm     N.A.        9           9           11          18
Nitration              A/cm     N.A.        25          16          9           8
Sulfation              A/cm     N.A.        5           6           5           9
Dispersing Power          %     N.A.        97          95          97          92
Carbon-Particulate Index  -     N.A.        < 0.1 (OK)  -           -           -
Flashpoint               °F     430         N.A.        N.A.        N.A.        N.A.
Insolubles                %     TR          N.A.        N.A.        N.A.        N.A.
ADDITIVES
Calzium        Ca     mg/kg     2471        2291        2475        2703        2179
Magnesium      Mg     mg/kg     300         444         134         94          249
Boron           B     mg/kg     19          12          16          34          32
Zinc           Zn     mg/kg     916         939         938         1072        1009
Phosphorus      P     mg/kg     764         695         666         821         826
Barium         Ba     mg/kg     0           0           0           0           0
Molybdenum     Mo     mg/kg     62          63          60          61          2
Sulfur          S     mg/kg     N.A.        2150        2179        2482        3420
ADDITIONAL TESTS
T/BN                mgKOH/g     3.2         6.39        6.50        8.00        7.27
REPORT #4:
  Subject   : Mobil 1 Peak Life 5W-50, BMW E39 540iA, 27262 km (oil), 127155 km (total)
  Additive  : Liqui Moly Visco-Stabil (VI improver) (added several times over oil usage, 1 liter in total)
  Oil Usage : 10.5 month
    The wear values of iron and aluminum are higher than expected, but not yet critical. Possible
    components affected are pistons (Fe) and cylinders (Al). Lead and copper are possibly increased
    due to wear of bearings.
    The water content is higher than normal. Possible causes: condensate formation due to short-time
    duty, leakage of the coolant circuit.
    The additivation deviates from the fresh oil reference in our database. This can most probably
    be traced back to the addition of additives.
    The nitration value (NOx) is considerably increased. Possible causes: increased blow-by, mostly
    caused by poor combustion, insufficient sealing between pistons and cylinder walls or valve
    problems. The gasoline quality or a non-optimal engine configuration may also have an influence.
    Increased sludge formation may be the consequence.
    The base number BN is considerably lower than expected.
REPORT #3:
  Subject   : Mobil 1 Peak Life 5W-50, BMW E39 540iA, 22081 km (oil), 99893 km (total)
  Oil Usage : 6 month
    The values of wear increased only slightly. This minimal wear is within normal range.
    The nitration value (NOx) is increased. Possible causes: increased blow-by,
    mostly caused by poor combustion, insufficient sealing between pistons and
    cylinder walls or valve problems. The gasoline quality or a non-optimal
REPORT #2:
  Subject   : Mobil 1 Peak Life 5W-50, BMW E39 540iA, 17762 km (oil), 77812 km (total)
  Additive  : Liqui Moly Visco-Stabil (VI improver) (added after 12500 km usage)
  Oil Usage : 4 month
    The values of wear are within normal range.
    The base number BN is slightly lower compared to the fresh oil reference.
    All other values are within normal or expected range.
REPORT #1:
  Subject   : LM Top Tec 5W-40, BMW E39 540iA, 7200 km (oil), 60050 km (total)
  Oil       : Liqui Moly Top Tec 4100 5W-40
  Oil Usage : 5 month
    The values of wear metals have risen only slightly.
    This low wear is within the normal range.
    The values of additives differ from the values of the fresh oil reference in our database.
    The fuel content is negligible and is below the detection limit.
Pinky
Germany
As before I am using the Wynn's Engine Oil Stop Leak mainly to "re-soften" the VANOS seals, which finally seems to work out as expected: the engine has full torque (at least it feels like that) in the lower RPM range and the average fuel consumption dropped?! I still try to avoid touching any internals of the engine, i.e. replacing the VANOS seals. Furthermore I am using the VI improver to maintain a proper high temperature viscosity value, as, at least from what I have heard, the wide spread engine oils with respect to cold and hot viscosity deteriorate faster than other oils?!
Virginia
Great report. 20k km appears to be no sweat. I think you could skip the additives and just top off with the 5W-50 M1.
Pinky
Germany
By the way: in the Blackstone report, what exactly does TR stand for in case of insolubles?
