I can tell you what he thinks....
![[Smile]](images/icons/smile.gif)
, At the time of this video, Mobil had just came out with the SuperSyn and this just appeared on the local parts house shelf. The test showed that the new antiwear barrier additive they touted was bogus in respect to the timken and qualified by oil analysis at that time as well.. It was shortly after that, that new analysis was coming back with Moly added in the mix where it wasn't before, so the test was rerun, and it did exceptionally well and no longer is that test valid in relation to how the oil is now. It does however provide a lesson in the differences on how a barrier additive can make a difference. So, as pointed out before since the change, I have retracted my comments on that video and now stand by that it has proven to be one of the higher quality oils since the reformulation of that first one. Hope that helps explain what I think now about that video. I guess I need to change that up in someway to clear up the confusion it leads to and really isn't fair for them either since it is a top notch oil.
bob
