CarfriendXX
- Joined
- Aug 6, 2021
- Messages
- 355
I only use this mobil 1 in this car, no other engine oil. I use ist, because the results are very Good and the engine have a smooth Sound .
Dealer oil is M1 0w-40, and not many use 0w-20 due to the price.0w40 accomplishes nothing special here, you have a basic 1.8 Honda motor that is not stressed out at all. This makes 138 hp at the crank, what justifies using a thicker oil over 0w20/0w30?
Use what best suits your needs and your wallet. Even if you start using the best oil on the planet, someone will still chime in and tell you to use something else. Just the human nature, I guess. Mobil 1 is doing a great job for your engine with your operating conditions. I see no reason to change anything.The price of this mobil1 is Perfect and i can use it Ober long distances, not only 10000kilometres. So i use this, other oils can be expansive and the results would not ne better. My Honda dealer use total Engine oil, i buy mobil 1 from a oil dealer since 16 years.
Why should i use an other Engine oil ?
How's 0W20 going to hold up after a full OCI of Autobahn driving? Don't think it would do too well. Less protection at higher cost. (German prices.)0w40 accomplishes nothing special here, you have a basic 1.8 Honda motor that is not stressed out at all. This makes 138 hp at the crank, what justifies using a thicker oil over 0w20/0w30?
isn't there some highways in Hot Desert part of US where on some highways there are no speed limits? Texas, New Mexico or Arizona may be?Holy schnitzel. Impressive. I had a 2010 Honda Civic with same 1.8L R18 engine, and fastest it would do is ~200km/h. I guess I just didn't have enough of straight road to truly max it out. We need Autobahn in USA...
I get it 10W30 is a more stout 30wt oil as compared to 0W/5W-30? what is so special about M1 EP 10W30 (in comparison to other long drain interval oils), I suppose this oil too can be had at killer price during sales+rebates whenever and where they occur? am I not right?Didn't know little Civic can go faster than 90mph (145 kph) for an extended period of time and not blow up! lol j/k
At those speed with small engine, I would stay away from 0W-20. I personally stay away from 0W-20 with any engine but I know some people like it.
I'm currently running M1 FS 0W-40 in one of our cars that has a 5W-20 manufacturer spec. This poor car has never seen a xW-20 except the factory fill and I don't think ever gone over 85 mph.
at your speed 40 may not be a bad idea but curious if you have any M1 EP 10W-30 uoa since you do extended drain? That's another good oil if you are within 10W temp range in your area. The people on that forum who are worried about plastic can't argue much with a solid 10W-30. M1 EP 10W-30 is more expensive than M1 FS 0W-40 in US.
I am baffled how there has been no drop in TBN after 10k km/6K miles of usage (i do see you topped up 0.8L), given your high quality gas, mostly hwy miles, mostly high speed driving, M1 0W40 seems to fit the bill perfectly and no need to worry given its not a Asian turbo engine... This oil will keep serving you till the end of the car's life.Here my new analysis from my dayli car. If you would compare the other results of this paper, you can See that i can use this Engine oil longer than 10000 kilometers.
If you calculate the wear down to 1000 kilometres, the 20000 analysis is better
In some German forums, silly talkers are who think that a 0w40 is a "polymer bomb" and is not as stable as a thicker base oil. I think I can refute these blanket statements more and more. For me, Mobil 1 is still the best!
No roads without speed limit here. Highest legal speed limit is 85MPH (~136KM/H), realistically traffic moves at 90MPH-100MPH (~145-160KM/H)there though. Faster than that will get law enforcement's attention.isn't there some highways in Hot Desert part of US where on some highways there are no speed limits? Texas, New Mexico or Arizona may be?
