Just did my first UOA. Below are the details and results.
Make: Honda Jazz GE8, YOM 2008
Odo Mileage: 100,000 km
Oils used: Amsoil ATM 10W30 from 1k to 10k. Thereafter Mobil 1 EP 5W20 every 10k.
Oil hour for this sample: 10,000 km
Comments:
All wear levels appear within acceptable limits for first sample. Silicon level (dirt/sealant material) abnormal. Water content satisfactory. Fuel dilution satisfactory. Viscosity within specified operating range.
Action: Check for point of dirty entry. Resample at next recommended interval to monitor and establish wear trend.
I'm quite new at this so would like to hear your comments on the results. Does it look just ok, or not bad, or pretty good?
As for silicon level... i'm not sure what could be the cause.
Anyway, base on the numbers alone, is there a set of "specifications" that one can compare with to judge whether it's ok or not?
Code:
Aluminum 2 Copper 1 Chromium <1 Iron 8 Lead <1 Tin <1 Nickel <1 Silicon 72 Boron 133 Sodium 4 Potassium 3 Phosphorus 708 Molybdenum 112 Magnesium 13 Calcium 2541 Zinc 826 Water <0.1 Nitration (Abs) 14.1 Viscosity (cSt,40degC) 48 Glycol (Abs) <0.1 Petrol (% by distillation) 2.0
