Your twisting his words again!So that means AFE that has no PAO or very little is better for anti-wear than EP with PAO. Wow
Ok, I wont, just was not sure what the comment was for.Your twisting his words again!
SP oils are better than previous oils as preventing wear. PAO isn't the best at preventing wear.
Who says that PAO not good ? The anti-wear magic is all in additives
That is not what he said.
Mine was louder with PUP … and unlike most I used a dB meter … Changing from 30 to 40 was quieter …Mine sounds the same with PUP or EP
I was of course kidding. Its top notch stuff.Mine sounds the same with PUP or EP
How did you come to this conclusion?……. stronger additive pack.
Product descriptionHow did you come to this conclusion?
Don’t know but It’s still all over their site, same with the 30.M1 0W20 for engine rated for 5W20 ? I believe Mobil removed the jug comment that the 0W20 was suitable for 5W20 applications a year or so ago ... Was this for legal or some sort of practical reasons ?
No engine is “rated” for a particular winter rating.M1 0W20 for engine rated for 5W20 ? I believe Mobil removed the jug comment that the 0W20 was suitable for 5W20 applications a year or so ago ... Was this for legal or some sort of practical reasons ?
Shouldn't matter especially if its syn, alot of times 0 winter rating oils are thicker than 5w above 0 degrees F.M1 0W20 for engine rated for 5W20 ? I believe Mobil removed the jug comment that the 0W20 was suitable for 5W20 applications a year or so ago ... Was this for legal or some sort of practical reasons ?
I used to think the same thing until another member with a Ford F-150 posted UOA results that were strikingly similar with an ever-so-slight improvement with AFE. This was over a series of OCI, not just one or two.I am not sure AFE makes sense when EP is only $2 more for 5qt
My understanding that in this particular cause UOA would look similar with not only M1 oils, but many others.I used to think the same thing until another member with a Ford F-150 posted UOA results that were strikingly similar with an ever-so-slight improvement with AFE. This was over a series of OCI, not just one or two.
