It's been a while since we saw a VOA of Mobil 1 Extended Performance, so, since I saw on my recent last oil change the Mobil 1 Extended Performance 5w30 that I use had on the bottle itself gone to ILSAC GF-4 and API SM lables, I thought it'd be interesting to see what a VOA looked like, with TBN.
Enjoy!
Results:
Code:
Element VOA
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 80
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 80
Silicon 5
Sodium 3
Calcium 2161
Magnesium 13
Phosphorus 631
Zinc 672
Barium 0
SuS@210F 64.2
Flash_F 440
Fuel % -
Antifrz% -
Water % 0.0
Insoles% 0.0
TBN 10.0
Blackstone Comments: The TBN of this oil read 10.0, very high. 1.0 is considered low. The viscosity of this oil was in middle of the SAE 30W range and no moisture was found. It would be correct for a 0w30 or 10w30 as well. The molybdenum is an anti-wear additive as are phosphorus and zinc. Boron, calcium (the dominant additive), and magnesium are all detergent/dispersant additives. Silicon is an anti-foam additive and sodium is a trace element and not a problem. This oil should serve your engine(s) well.
Chuck
Enjoy!
Results:
Code:
Element VOA
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 80
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 80
Silicon 5
Sodium 3
Calcium 2161
Magnesium 13
Phosphorus 631
Zinc 672
Barium 0
SuS@210F 64.2
Flash_F 440
Fuel % -
Antifrz% -
Water % 0.0
Insoles% 0.0
TBN 10.0
Chuck
