Patman
Staff member
So as some of you know, there is a new dexos2 certified 0w40 Mobil 1 which is now the factory fill in 2019 Corvettes, and is backwards compatible to any prior Corvette engines that require a dexos certified oil. As I have mentioned in a couple of different threads now, it causes me to be interested in a couple of other dexos2 oils, but one in particular is Mobil 1's 5w30 ESP. And in looking at all of the technical data, it looks on paper like the 5w30 ESP might be a better choice than the 0w40 ESP.
For instance, the HTHS of the 5w30 is higher (3.58 vs 3.53) Sulfated ash on the 5w30 is listed at 0.6, the 0w40 is listed as 0.8. And the flashpoint of the 5w30 is also higher, at 254C vs 234C for the 0w40.
So if it turns out I can use the 5w30 ESP and retain my warranty, which of these two oils would you choose?
Here is more info on both of these oils:
