New sample on right.
Code:
Date out: 3/03 6/03 11/03 11/03 5/1/04 1/28/05 7/4/05 8/6/06 1/21/07
Lab: OG OG OG Black Black Black Black Black Black
Brand: Chevron M1 M1 M1 M1 M1 M1 M1 M1
Supreme
Weight: 10w30 5w30 5w30 5w30 0w20 0w20 0w20 5w20 5w20
Miles on unit: 10170 15056 22476 22476 30067 40257 49984 65663 74980
Miles on oil: 5072 4886 7420 7420 7591 10190 9727 7086 9319
Gallons: 188.4 182.3 277.1 277.1 284.9 386.4 335.5 265.1 349.0
Filter: Honda Honda Honda Honda Honda Honda Honda Honda Honda
Fram Fram Toyo-R Toyo-R Toyo-R Toyo-R Filtec Filtec Filtec
Make up: 0 0 1/3 1/3 1/4 675 ml 1 L 500 ml 500 ml
Al- 8 5 3 3 3 2 2 2 3
Cr- 1 0 0 0 0 1 1 0 0
Fe- 8 2 0 7 6 6 9 6 10
Cu- 15 5 6 5 3 6 5 5 5
Pb- 4 0 0 3 3 6 11 7 3
Sn- 0 0 0 1 3 0 2 1 0
Mo- - - - 76 82 53 89 83 83
Ni- - - - 0 0 0 0 0 0
Mn- - - - 0 0 0 0 0 0
Ag- - - - 0 0 0 0 0 0
Ti- - - - 0 0 0 0 0 0
K- 5 0 0 0 1 0 0 0 1
B- - - - 135 149 90 141 55 64
Si- 40 15 14 10 9 9 11 10 13
Na- 10 11 17 8 8 5 7 6 9
Ca- - - - 3517 2666 2553 2802 2342 2243
Mg- - - - 18 22 11 20 15 14
P- - - - 798 778 602 719 669 628
Zn- - - - 894 929 752 865 793 734
Ba- - - - 0 0 0 0 0 0
Sus@210 - - - 61.0 57.7 58.3 58.3 53.3 55.9
Flashpoint - - - 385 445 445 435 420 395
Fuel -
Glycol- none none none 0.0 0.0 0.0 0.0 0.0 0.0
water -
Insolubles - - - 0.2 0.2 0.3 0.4 0.2 0.2
Oxidation - 6.3 10.8 13.5 - - - - - -
Visc@100- 13.7 13.0 13.3 - - - - - -
Nitration - 4.3 4.9 5.3 - - - - - -
Sae-
TBN 4.0 5.8 5.5 4.3 5.5 - 3.4
OG=Oil Guard/MTM Black=Blackstone
There was more highway than normal in this interval probably 40% traffic, 60% highway. The gearing in my car places my engine at 4000rpm, probably not the easiest of rpm range. No auto-x in this range, but a decent amount of WOT. No fuel or oil additives.
I am happy that the lead is down, I think it was a particle streak. It looks like I need to take a look at the air filter. Could the high si cause the higher iron levels? Although just looking at the numbers the report appears to be pretty good. Any thoughts or suggestions?
Code:
Supreme
Fuel -
water -
Sae-
