Yawwwwwwww nnnnn
Hyundai Elantra 2005
Oil type Mobil 1 5w/30 extended performance
Millage 6,128
Millage on engine 118,251
1 quart added
Comments:
Ken, Thanks for the note about the short highway trips and dusty wheat fields. Silcon is nice and low, so we don’t see any negative effects from the dusty fields. Perhaps if we tested for pollen we might find something, but that shouldn’t cause wear so we don’t have any immediate plans to add that to our repertoire. Iron was a little higher than average. This is from steal parts and might also be a function of the use this engine sees. Other metals are fine. So let’s just see where iron goes next time. The TBN was 2.9 which is fine since 1.0 or less is low. Try up to 8,000 miles.
Code:
Aluminum 4 Chromium 1 Iron 21 Copper 0 Lead 0 Tin 2 Moly 99 Nickel 0 Manganese 0 Silver 0 Titanium 0 Potassium 2 Boron 28 Silicon 7 Sodium 82 Calcium 1100 Magnesium 580 Phosphorus 670 Zinc 770 Barium 0 Properties: SuS Viscosity @210F 58.9 Range 56-63 cST Viscosity @ 100C 9.91 Range 9.1-11.3 Flash Point 410 Ranger >365 Fuel % <.5 Range <2.0 Antifreeze % 0.0 Water % 0.0 Insolubles % 0.3 Range <0.6 TBN 2.9
