Blackstone Comment: We don't know where the silicon is from, but with wear reading perfectly normal, the silicon is not abrasive dirt. It is silicone compound of some sort. Universal averages show typical wear metals for an oil from this type of engine after about 4805 miles run on oil. Your oil was in use just longer, and we found all wear at around average levels and in corrct balance to show normal mechanical parts inside. No metals from bearing wear were detected. No gas or anti-freeze was found. The TBN was 1.8, getting low. A perfect engine! Try 5,500 milescode:
Model Year 2003
Make Lexus
Model ES300
Add'l Info 1MZ-FE
Oil Type&Grade Mobil 1 EP 5W-30
Add'l Info SM
Sample Date 09/13/2005
Miles on Oil 5075
Miles on Unit 24226
Time on Oil 6 months
Make Up Oil 0 (poss 0.25 qt)
Oil Filter 90915-YZZD1
Air Filter Stock
Testing Lab Blackstone
Aluminum 2
Chromium 0
Iron 7
Copper 1
Lead 0
Tin 0
Molybdenum 70
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 95
Silicon 28
Sodium 5
Calcium 2536
Magnesium 15
Phosphorous 701
Zinc 859
Barium 1
TBN 1.8
SUS Vis @ 210 F 64.2
Flash (F) 355
Fuel % 0.5
Antifreeze % 0
Water % 0
Insolubles % 0.2
My comment: I appreciate comments. I have been lurking for a while; this is my first post. This Lexus (Toyota) is my mom's car. The sample was done during an oil change. I refilled the crankcase with Mobil 1 5W-30 SS.
The car is driven about 80% short trip city driving in Miami, FL. I don't remember if I added make up oil. If I did, it was maybe about 0.25 quarts.
I went ahead and changed the air filter. The air filter was dirty. I did the UOA on the Mobil 1 EP hoping to see if I could get more than the 6 months or 5k miles. I was dreaming of at least 9 months or 7.5k miles or even 1 year or 10k miles.
I think I will stick with the current 5k miles OCI. I may eventually switch to 10W-30 once the warranty expires.
I would appreciate any advice on how to line up the info better. I put it in a spreadsheet and used the Code function.
My dad has an 05 ES 330 that is running with Castrol Syntec Blend and I have an 03 MB E320 with Mobil 1 0W-40. I will post my findings on those vehicles too.
Thanks,
William
[ September 14, 2005, 11:06 PM: Message edited by: 59 Vetteman ]
