Comments: Switched from dealer serviced Syntec Blend 10W/30 with BGMOA to M1. Honda Filters.
Comments from Blackstone:
This is the first sample we've seen out of your Acura, so we don't know for sure what lead looked
like prior to this. But when we see a mildly elevated level of lead like this, we tend to think it's from a
temporary particle streak through the bearings. If so, it will improve next time. Upper-end wear is great and
the engine is otherwise in good shape. The viscosity was normal for a 5W/30 and no fuel, antifreeze, or
moisture was present. Insolubles (which are oxidized solids) read low at 0.3%, showing good oil filtration.
The TBN read 2.8, okay. Try 10,000 miles next.
Code:
OIL M1 5W/30 MILES IN USE 7,170 miles MILES 134,576 miles SAMPLE TAKEN 05/10/2011 Univ Avg; ALUMINUM 4 3 CHROMIUM 1 1 IRON 19 12 COPPER 3 21 LEAD 11 1 TIN 1 0 MOLYBDENUM 92 81 NICKEL 1 0 MANGANESE 0 1 SILVER 0 0 BORON 42 43 SILICON 10 12 SODIUM 20 30 CALCIUM 2328 2184 MAGNESIUM 12 32 PHOSPHORUS 670 651 ZINC 691 793 BARIUM 0 0 INSOLUBLES 0.3% WATER 0% FLASHPOINT ºF 380 SUS VIS 210ºF 58.4 cSt @ 212ºF 9.76 Fuel <0.5 TBN 2.8
