Comments from Blackstone:
Yep, lead is coming down. It's not perfectly normal just yet, but give it another oil change or two
and it should drop more than this (assuming the bearings are wearing well). All other wear is pretty steady.
Iron increased a little, and if you go ahead and take your next oil change up to 9,000 miles, it will increase
more. You can figure out how much iron you're getting per mile by dividing iron by miles on the oil. As long
as that rate stays constant, then the higher iron (or other metals) won't be a problem. The TBN read 3.1, still
good. No contamination found.
Code:
OIL M1 5W/30 MILES IN USE 7,078 miles MILES 141,454 miles SAMPLE TAKEN 01/03/2012 Univ Avg; ALUMINUM 4 3 CHROMIUM 1 1 IRON 24 12 COPPER 4 21 LEAD 8 1 TIN 0 0 MOLYBDENUM 108 81 NICKEL 1 0 MANGANESE 0 1 SILVER 0 0 TITANIUM 0 0 POTASSIUM 3 1 BORON 54 44 SILICON 17 12 SODIUM 13 30 CALCIUM 2347 2201 MAGNESIUM 138 33 PHOSPHORUS 766 655 ZINC 796 793 BARIUM 0 0 INSOLUBLES 0.3% WATER 0% FLASHPOINT ºF 390 SUS VIS 210ºF 59.6 cSt @ 212ºF 10.10 Fuel <0.5 TBN 3.1
