Here are the two UOA's performed with Mobil 1 5W-30. I've now moved on in my oil sampling with this car to Redline 5W-30.
Important note about the fuel dilution results: 1st sample (1st 5K oci) was done with a short warm-up before drain - 3.8% fuel dilution on a new engine!; 2nd sample (2nd 5K oci) was done after 20 minutes of driving, so the engine had been fully warmed before draining. I found similar variations in fuel dilution with my previous Audi 2.0T (1st generation DI with timing belt).
Code:
Oil Tested M1 5W-30 M1 5W-30
Mi on Oil 5000 5000
Mi on Engine 8000 13000
Sample Date 11/11 4/12
Make-Up Oil 0 0
Aluminum 8 8
Chromium 1 1
Iron 17 17
Copper 10 7
Lead 1 0
Tin 0 0
Molybdenum 211 90
Nickel 0 0
Manganese 2 1
Silver 1 0
Titanium 1 0
Potassium 1 3
Boron 50 40
Silicon 27 19
Sodium 21 6
Calcium 2541 1417
Magnesium 11 715
Phosphorus 731 704
Zinc 818 782
Barium 1 0
SUS Vis @ 210F 51.6 52.2
cSt Vis @ 100C 7.77 7.93
Flashpoint (F) 290 375
Fuel % 3.8
Antifreeze % 0 0
Water % 0 0
Insolubles % 0.2 0.3
Blackstone summary comments:
Sample 1: Typ wear levels for new engine
Steady wear metals
High Al, Cu, Si likely residual wear
3.8% fuel dilution is cautionary
Sample 2: Fuel dilution has disappeared
Al is OK, Cu is normal
Visc dropped to 5W-20
Code:
Mi on Oil 5000 5000
Make-Up Oil 0 0
Aluminum 8 8
Chromium 1 1
Iron 17 17
Copper 10 7
Lead 1 0
Tin 0 0
Molybdenum 211 90
Nickel 0 0
Manganese 2 1
Silver 1 0
Titanium 1 0
Potassium 1 3
Boron 50 40
Silicon 27 19
Sodium 21 6
Calcium 2541 1417
Magnesium 11 715
Phosphorus 731 704
Zinc 818 782
Barium 1 0
Fuel % 3.8
Antifreeze % 0 0
Water % 0 0
Steady wear metals
