Al, that's a M-1 overseas spec. sheet from 1995. However, it does illustrate the point. Yes, Mobil 1 has been brainwashing the public by pushing it's "pours at -400 or whatever" for the longest time. This is a characteristic of PAO's.
In either case, a 15-50 is generally good down to -20C (-5F) (as per my owner's manual). With Mobil 1 you may be safer...I believe they say the pumping temp. is -35C...however, the oil will be molasses thick. If your engine can turn it over, it will pump and that's all that matter. I don't think this "it flows better or worse" thing matters.
All the engine parts are already coated...and the oil will reach the parts soon after the car is started....I mean, someone came up with the magical -20C...I didn't pull it out of my...
To finalize though, I found increased fuel consumption at these cold temps. until the oil warmed up...ie. fuel was being wasted to warm-up the oil....which was frequent during frequent short trips...this killed the fuel economy...not the 50 weight.
