Vehicle History
Dad's toy. The engine was rebuilt [hot-tank, cylinders bored, new pistons/rings etc.]
at 97358 miles on the ODO so I've reported the miles on engine as 7176, and miles on
vehicle as 104534.
OCI
This oil was in use for at least 2 years. The ODO definitely rolled over 00000 with
this oil sample in the sump, so there's at least 4600 miles on it. It might have been
Mobil 1 TriSyn SL as that's what I found in the trunk for top-up oil, of which 200mL
was used for top-up. There was at least one change before this was run.
My own comments : Lead is bad, iron is high. Silicon was suprisingly low considering what little faith I had in the air filter setup.
[ May 18, 2006, 06:46 PM: Message edited by: craigq ]
vehicle as 104534.
OCI
EDIT: I forgot, the first time on the road after the rebuild was summer 2002.code:
Sample Date 5/14/2006
Analysis Date 5/26/2006
Lab WearCheck Canada
***Vehicle ID***
Make MG
Model B
Year 1976
Engine 18V672Z 1.8L I4
Miles on Engine 7176
Miles on Vehicle 104534
***Oil Identification***
Oil Brand Mobil
Oil Series Mobil 1
Oil SAE J300 15W50
API SX SL
Miles on Oil 4600
Months In Service 24
***Elements***
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.2
Aluminum Al 3.6
Chromium Cr 6.2
Iron Fe 28
Copper Cu 6.2
Lead Pb 75
Tin Sn 0.9
Molybdenum Mo 73
Nickel 0
Manganese Mn 33
Silver Ag 0.6
Titanium Ti 0.1
Potassium K 1.3
Boron B 147
Silicon Si 8.4
Sodium Na 17
Calcium Ca 3105
Magnesium Mg 63
Phosporus P 1175
Zinc Zn 1387
Sulfur 2630
Barium Ba 0.6
***Viscosity***
cST @ 100 C 14.9
SUS @ 210 F NR
***Misc***
Flashpoint (F) NR
Fuel %
Antifreeze % NR
Water %
Insolubles % NR
Sulfur 16
Oxidation 33
Nitration 15
ZDDP 18
TBN NR
TAN 3.09
Ferrous Debris NR
Fuel Soot % 0
Glycol NR
ISO Code NR
Additives None
URL NR
Notes Lab reports wear rates are normal,
and to resample at the next service interval to monitor.
Location Ottawa, ON, CAN
***Filters used***
Air Filter UNI Pancake Filters
Oil Filter Motomaster Formula 1 F1-43
***Particle Count***
>2 micron NR
>5 micron NR
>10 micron NR
>15 micron NR
>25 micron NR
>50 micron NR
>100 micron NR
