Here is my recent UOA from Blackstone. I ran regular Mobil 1 10W/30 for 5,010 miles (the OLM stated 23% oil life left). Truck is a 2006 and has the 345hp 6.0L with 9,953 miles on it as of this oil sample.
Blackstone Comments:
Well, 23% life left...that might be a little optimistic, in our view. Not that anything here
shows a problem. In fact, we think this is going to be a very nice engine for you. But it's still wearing in,
and copper will linger high for a while yet, and we like to see this wear-in stuff get removed from the
engine sooner, rather than later. So we think you did good by changing this oil when you did. The TBN
read 4.0, still active additive remaining. We suggest sticking with 5000 miles on the oil for now. Once
things settle down, you'll be able to run the oil longer.
DATA:
aluminum - 4
chromium - 1
iron - 31
copper - 142
lead - 7
tin - 1
moly - 85
nickel - 1
manganese- 3
silver - 0
titanium - 0
potassium- 3
boron - 56
silicon - 35
sodium - 68
calcium - 2125
magnseium- 11
phosphorus-572
zinc - 690
barium - 0
sus viscosity at 210 degrees = 62.7
flashpoint = 405
fuel = 0.5
antifreeze = 0
water = 0
insolubles = 0.3
TBN = 4.0
Not much change since the last UOA at 3,078 miles where I had Mobil Clean 5000 in it. You can search for that UOA if you want. I'll probably not get another UOA until about 20,000 miles and see how things are and keep the OCI between 4-5,000 miles until then. I'll probably also stop using Mobil 1 when my stash runs out, but am not fully decided yet...and I don't want to start a thread about that!
DATA:
aluminum - 4
chromium - 1
iron - 31
copper - 142
lead - 7
tin - 1
moly - 85
nickel - 1
manganese- 3
silver - 0
titanium - 0
potassium- 3
boron - 56
silicon - 35
sodium - 68
calcium - 2125
magnseium- 11
phosphorus-572
zinc - 690
barium - 0
flashpoint = 405
fuel = 0.5
antifreeze = 0
water = 0
insolubles = 0.3
TBN = 4.0
