Mobil 1 0W40, 5055 mi, Infiniti G37S VQ37HR
SC
Mobil 1 OW40 5055mi Measured slightly low viscosity. My previous fill was Motul 5W40 which usually holds up well but also showed breakdown after one track day. Initially I thought maybe the Motul was showing low viscosity due to dilution from a previous fill, but the M1 is also showing some breakdown. Am I reading this analysis correctly? Thoughts?
Canada
This thing got an oil cooler? that would explain the copper. Not bad results for an engine that is known to be hard on oil. M1 0W-40 does usually shear to 11-12 cst; it's just the nature of the beast, and not a problem. I'd give M1 TDT 5W-40 a try, and see how it does for comparison.
MiLKMD
SC
No oil cooler. I do monitor temps during runs and have temps 220 - 240 F on occasion but not for this particular fill. Thanks for the comment about the behavior of M1 0W40. I had heard similar reports before. And this report confirms what everyone has been saying about this engine on oil, which is why I run out of spec. I do also monitor pressure and operating pressure has been within spec at temp.
Ponte Vedra Beach, FL
Thanks for your informative post. Nice results overall. I wonder how Valvoline SynPower, MST, 5w-40 would hold up for 5K-6K instead of Mobil 1, 0W-40? Thanks for sharing. Cheers!
MiLKMD
SC
Already on it. Thanks! Will keep you posted.
Clovis, CA
Iron -10, Copper - 28, Lead - 8, viscosity down to a 30 weight ... and you guys say Mobil 1 0W-40 is the best oil on the market? popcorn
MiLKMD
SC
I haven't tried GC. I couldn't find the Euro version last time I went looking.
Indiana
You must be new, welcome to BITOG! welcome Using standard UOAs to determine wear levels is a common fallacy, especially without knowing the "upper limits". Even more true when comparing different engines and different oils.
Great Lakes
How did you come to the conclusion that it was the oil's fault? As for the viscosity, this oil starts out as thin 40. Now it's showing as thick 30. Slight viscosity fluctuations are quite normal. No oil is 100% stable.
OVERKILL
$100 Site Donor 2021
Ontario, Canada
NJ
LOL
NY
Are the specs on this engine the exact same as the 370z? Nissan dealers are pushing their "Ester" for this motor. The local dealer makes it sound like their oil is pure ester oil.
Saratoga, NY
Not sure the extra copper is whear ... I'd expect the lead to be elevated, too. Tin is zero so it's not a bronze component that's wearing. Maybe a chemical reaction from the add-pack or the add-pack and the byproducts of combustion? I suspect the loss of viscosity may be some fuel contamination that does not always show up on UOAs. A pure ester oil would likely be too aggressive on soft metals ... look at Red Line Oil UOAs. It would also be $10+ per quart retail.
MiLKMD
SC
The specs are the same. I have not heard good things about Nissan's ester oil although to be clear, I have never used it myself. The opinion is just from a number of users on here and on other enthusiast websites and the consensus is that Nissan's ester oil shears quickly and does not hold up even under normal driving conditions. Most VQ drivers who use ester based usually recommend Redline or Motul. Most of the track drivers I have spoken with recommend Motul as well, but it is extremely expensive.
JAG
Fredericksburg, VA
The ester in the Nissan oil is simply a friction reducing additive. It's not a base oil. It's meant to be good at friction reduction on DLC surfaces in the Nissan engines that use it. Other than possible improved fuel economy, the oil appears to perform with lackluster and it's very overpriced. Even people on BITOG were fooled by what Nissan meant by "ester" by assuming it was a base oil, making it somewhat like Red Line and some Motul oils. That's a shame.
Burlington, Ontario, Canada
With the high moly, this oil undoubtedly has a lot of the previous Motul in it. Anyway it's a good report with the exception of the high Cu. Since you're running M1 0W-40 again, a UOA of the second run will be more telling.
