D Donrim Joined Dec 11, 2006 Messages 10 Location Illinois May 20, 2009 #1 The sample was taken close to the end of the drain (less than a quart drained after the sample was taken) as I almost forgot and had to find the bottle. I wonder if the high fuel content has anything to do with that.
G Gary Allan Joined Sep 28, 2002 Messages 39,799 May 21, 2009 #2 Was it drained hot? You've got consistent noise There's hardly any difference between the two like mileage UOAs ..even 11k apart. If I read the dates correctly, you took 21 months to go 11k. That's either some serious short trip usage, or some severely limited usage.
E e40 Joined Mar 15, 2008 Messages 386 Location Wisconsin Jun 4, 2009 #3 Check the PCV system, that could be the source of the fuel. I went through the same thing on my 1.8T http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Board=3&Number=1241739
