First oil analysis from oldest daughter's recently purchased used 2001 Honda Accord EX 4 cylinder. Car had 37,723 miles, with 5,420 miles on the Mobil 1 SS 0w30. Blackstone did the analysis.
Report is nothing exciting, but I post it because I do not see many UOA's with Mobil 1 0w30. I usually use Amsoil, but used Mobil 1 due to quick availability amd shortage of time ... mine.
Posting format: our car / Blackstone univerals
Aluminum 4/4
Chromium 1/1
Iron 9/9
Copper 4/3
Lead 3/1
Tin 0/1
Molybdenum 63/90
Nickel 0/0
Manganese 0/3
Silver 0/0
Titanium 0/0
Potassium 2/1
Boron 89/68
Silicon 8/12
Sodium 5/12
Calcium 1975/2595
Magnesium 6/54
Phosphorus 621/742
Zinc 707/877
Barium 0/0
Viscosity @210 F s/b: 55-60 was: 57.5
Flashpoint s/b: >360 was: 390
Fuel% s/b: Antifreeze s/b: 0 was: 0
Water: s/b Insolubles s/b:
Comments:
Steve, looks like you bought a good one. No problems showed up in this sample from the Accord. All wear read right around averages for this type of engine, which is a very good indication of normal wearing parts. The universal averages show normal wear after 6200 miles on the oil. Insolubles, oil oxidation due to heat, use, and blow-by, were normal at 0.5%, showing good oil filtration. No fuel dilution or anti-freeze was found. The TBN read 4.7, so the oil still has plenty of active additive. Oil changes at 5000-7000 miles won't be a problem for this Honda.
I forgot to mention, oil filter used was Napa Gold.
Both daugher's are having good luck w/ 4 cylinder Accords.
Any comments?
Steve
Aluminum 4/4
Chromium 1/1
Iron 9/9
Copper 4/3
Lead 3/1
Tin 0/1
Molybdenum 63/90
Nickel 0/0
Manganese 0/3
Silver 0/0
Titanium 0/0
Potassium 2/1
Boron 89/68
Silicon 8/12
Sodium 5/12
Calcium 1975/2595
Magnesium 6/54
Phosphorus 621/742
Zinc 707/877
Barium 0/0
Comments:
Any comments?
Steve
