engine has over 100,000 miles, oil filter Fram XG with the wire mesh backing. Air filter was STP made in Israel. Replacement identical but Purolator brand.
Pb 6
Cu 1
Cr 1 (previously 0)
Fe 17 (previously 7 after 5500 miles)
Si 13 (prev 10 after 5500 miles)
Na 15
moly 95, zn 788, p 759, mg 11
visc 8, TBN 3 (pretty good for that long and over winter)
nitration flagged as elevated, no fuel, glycol or water
Drain plug magnet showed excess iron. Air filter leaking slightly in a couple of spots at the clamshell hinge side of the housing, where pressure is not maintained by spring clips. I won't leave the filter in for this long (58,000 miles) now that I know the filter housing is unable to maintain pressure against the seal as the seal ages and shrinks. Filter is difficult to replace due to clamshell housing design and lack of room to swing the clamshell.
UOA led to detection of air filtration failure as cause of excess wear found by drain plug magnet.
Pb 6
Cu 1
Cr 1 (previously 0)
Na 15
