Mobil 1 0w-40 has Supersyn and no esters, D1 5w-40 has lots...
PA
I am already sold on D1/SUV and have'nt even used it. 0w-40 has Supersyn PAO and no esters verses D1 with loads of esters and no factory certs. Currently trying M1 0w-40 in a family car and it does burn off a lil fast. Planning on D1 for that car and a 2000 Mercedes, is that a good idea? I see there is no Supersyn on the D1/SUV bottle, that's Mobil's most advanced basestock, but D1 can do better without it? Curious about the comparison of these 2 oils.
Mobil 1 0w-40 DOES have esters. Not as much as D1 is reported to have (26%) but a good amount. M1 0w-40 is a better oil then most think. Yeah, it shears down to 12cSt oil but on a % basis, it's not that much at all. It's only 14.2 to start.
BTW, take note to how much higher the flash point is on the 0w-40 compared to their other oils.
[ April 11, 2004, 06:56 PM: Message edited by: buster ]
I'd run something that carries either the Mercedes 229.3 or 229.5 specifications in the Mercedes. Almost any oil will work in 95% of domestic engines ....
Tooslick
Dixie Synthetics
(256) 651-3590
I think the jury is still out on the 0W-40. I just haven't seen many UOA's...and the few that I recall....well frankly I don't recall
The 5W-40 "Delvac" seems good on paper and does good in pushrod engines....
No moly though...yes, I know it makes up for that lack of additives with others, but if it had some moly in it, I think this stuff would me untouchable. I thought esters were responsible for seal leaks.
I found this on another site. Has Mobil 1 given in and no longer a full PAO. Strange that it says "The Mobil 1 Tri-Synthetic Series motor oils are manufactured from 100% synthetic base stocks" but is listed under semi-synthetic. Has Mobil joined the dark side of synthetics? It also lists the Trisynthetic blend as API SL rated but only ILSAC GF-2 even though I had bought some MObil1 10-w30 SL oil that stated it was GF-3. I have been a long time satisfied user of Mobil1 but I'm becoming wary. Chevron Supreme is looking better all the time. Anyone have any insights into what's going on at Mobil?????
Isn't M1 0w-40 designed as an extended-interval fill and the "shearing effect" takes place because it's actually designed to do so?
Shears down so it doesn't get too overly viscous in the long run?
[ May 16, 2004, 09:40 PM: Message edited by: Jelly ]
Here we go again. Seems like we have to rehash this junk about Mobil 1 every couple of months.
Mobil 1 TriSyn isn't even made anymore. When it was, it had three synthetic base fluids: PAO, esters, and alkylated aromatics. The current version of Mobil 1 has PAO and alkylated aromatics (and possibly esters--the jury is still out on that).
