Originally Posted By: Jax_RX8
Originally Posted By: JohnBrowning
MMO would not be a good idea in a TDI. It is mostly Naptha like compounds and would open a diesel up to increased risk of lobe damage. Most gasoline engines have super easy cam knose loads and are rol
It does not have Naptha in it, which is a solvent - it has a Naphthenic oil base (as opposed to a parrafinic base oil) - about 70% of total.
Great info Jax
Can you explain the difference between Naptha, and Naphthenic oil base? This would be for people like myself who didn't do well in Chemistry class. Many thanks!
Heres a go:
Naphtha is a true solvent, like mineral spirits, etc. Basically, it is what is used in Coleman Lamps for fuel. Here is the Wiki data:
http://en.wikipedia.org/wiki/Naptha
There are two basic kinds of dino base oils - paraffinic and Naphthenic. Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster. Wiki does a great job of explaining, so I will quote them here and provide a link.
"Naphthenic oil is a type of mineral oil. In contrast with paraffinic oils, naphthenic oils contain only low to no proportion of n-alkanes, being based on cycloalkanes (naphthenes) instead. The low-temperature behavior of naphthenic oils is better than of paraffinic oils, making them suitable for applications that require low pour point. The degradation products of naphthenic oils are soluble in the oils, leading to fewer problems with formations of sludges and deposits. Naphthenic oils have different solvent properties than paraffinic oils.
Naphthenic oils are characterized by high proportion of cyclic hydrocarbon fraction. The convention is that when the paraffinic carbon content is less than 55-60%, the oil is labeled as naphthenic.[1]
The principial uses of naphthenic oils are as transformer oils, coolants, solvents, cutting fluids, and some lubricants."
http://en.wikipedia.org/wiki/Naphthenic_oil
