MMO in P/S
Kuwait
Friend of mine is due to replace his power steering fluid, and I recommended ARX to clean things up a bit. He isn't willing to pay the price for it, however. Having said that, he's asking if MMO be any good in the power steering system as an alternative. I said I didn't know. There's no mentioning of it on their website, but they do recommend it for automatic transmissions. Personally, I'd rather use ARX...but under these circumstances, it's not my car or funds to make a decision. Has anybody used it in power steering applications? Any recommendations? Thanks!
JHZR2
Staff member
New Jersey
Just flush the fluid a few times. Better off not adding things that are relatively unknown into such a system. MMO works great elewhere, and we have no reason to think it won't work well, but there is no basis to say that it will do anything either...
ON, Canada eh?
I would imagine adding MMO to PSF won't hurt, however I wouldn't add more than a couple of ounces. You could get 1 bottle of Redline or Amsoil PSF if available and dump it in and run it for a couple hundred miles. The detergents in these products should clean it up nicely. I did this with the Cabriolet. When I bought the car the PSF looked old and slimy, so not wanting to create leaks, I emptied out the small reservoir and refilled with Amsoil PSF and ran it like that for a while, slowly the clean fluid turned dirty... I drained it out and refilled it again for another cleaning cycle. It slowly cleaned up the system and now the fluid stays clean and no leaks.
gj
Pulaski VA USA
I have a 95' F-150 244 K I-6 that has a little whine to the power steering I may try that myself.I just bought some MMO because the truck has a rattle when it's in a pull I figure low octane/old age is the reason.Put some in my Kohler 26hp mower's gas tank also.What the heck I guess.
Falcon_LS
Kuwait
Thanks for the replies! \:\! Did a search on MMO's website, and it has never been tested in P/S application. However, apparently it uses the same base oil has power steering fluid and would cause no harm. It will thin the oil a bit, and make it flow better. The MMO representatives on the board recommend a dose of 10% MMO in your P/S reservoir. I will recommend a couple of system flushes and what I've found out about MMO in the P/S system. It's his choice to make.
