- Messages
- 122
- Location
- Franklin, TN
I changed my oil about 400 miles ago on my 95 camaro using 10w30 mobil 1 and an STP filter. The motor has 130k miles, and has loosened up enough where I want to run a little bit thicker oil, especially since it's been in the high 90's here in tennessee for the past little bit.
I have a pretty steady oil leak coming from the timing cover(which will be fixed after this oil change) and was wondering if it would be ok to add a quart of 15w50 mobil 1 to the mix when it gets low.
John
