509ci, iron head, big block chev, 13.7:1 compression ratio, loaded 5000-7000 rpm, start drag run at 140F water temp taken at top of the intake manifold.
Have 35 psi oil pressure at 1200 rpm - going to 65-75 psi at anything over 3000 rpm. Previously used Torco 10W30 conventional oil at request of engine builder.
I'd like to run Esso XD3 0-30 synthetic oil - given the low initial water temp and the good oil pressure I had with the conventional oil.
Torco typically has high levels of moly and tin (from what I read here) - MPZ formula - can I sustitute the XD3 and still provide the same engine protection?
I have no local Torco dealer (Canada) and have cases of the XD3 for my our daily van and car. Is an additive (sold in Canada) package suggested for the XD3?
I kept this out of the racing section since it really isn't that stout a package and has a reasonble low rpm range / soft ramp roller camshaft.
Please lend a hand with this street / strip combination.
MAT
MAT
