I have a 1mz-fe engine and replaced the gasket for the front and rear valve cover, I also remove 2 half moons on each and applied what I thought was my gray Permatex gasket sealer..I put everything back and have used it for 6 days with a total mileage of over 300 miles...then realize I made a big misake since what I used was actually Permatex 81343 anti-seize. So far the anti-seize is holding up pretty well and there are no leaks. I can see the beads formed by the anti-seize and it still looks like when I put it on. It has not dissipated or anything and actually surprised it is holding up. What is your opinion on this? Should I just redo it again (rear is very difficult) or should I just continue monitoring for oil loss? Also, will this affect my engine since anti-seize is more likely circulating inside the engine?
