Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 2,555
Rear diff fluid must be changed between 15k - 20k miles. I went to 25K since my engine oil % wasn't low enough, never bothered to look up the 6 meant in the B16 code on the maintenance screen was (change rear diff fluid). Could this have caused harm to the rear diff? I think the CRV is FWD biased unless you accelerate hard, then it seems to put more power to the rear wheels (according to the dashboard awd graphic)/ I presume the diff doesn't work that hard most of the time so maybe damage was averted? I am a little surprised the fluid needs to be changed so early but the service advisor stated this is a break-in fluid and wont need a change for another 50k IIRC.
