Originally Posted By: 4wheeldog
Originally Posted By: OneEyeJack
I run my Honda Michelin tires at 40psi. About 20 years ago this car (the one in my sig, I'm the original owner) was the subject of a friendly bet. We used a back street at an industrial park on Sunday morning and did a breaking test with the tires hot and at 32, 36 and 40 psi from an indicated 65mph. With 3 stops at each setting the best stopping distance by 9 to 11 feet was the 40 psi. We also set up a circle and drove around it. The 40 psi setting was much better but I don't remember any more how much it was. I do remember collecting the dollar from the bet and it's still taped up on the lid of my tool box. When Social Security crashes I'll be covered.
We did this testing with a couple of other cars and obtained similar results.
I get excellent mileage out of the tires at 40 psi and have had not problems beating up the suspension.
40psi hot is not the same as 40psi cold. A good rule of thumb is the tire pressure is optimum for roadholding and braking when checking them hot, they are 4psi above what was put in them cold.
Since your bet was based on hot temps, all things being equal, you should probably be running about 36psi cold. Just sayin'.
The tire pressures were set at 40 psi with cold tires. The gauge was a calibrated gauge. The tire test was run with hot tires, that is tires up to operating temperatures, also checked with a calibrated contact temperature gauge. One can't be too careful when there's a dollar at stake.
