As per title. By minor I mean on the order of a few tablespoons at most, coming from under the dash where the AC ducts are. Drip, drip, done. Carpets not soaked, no flooding.
Checked usual suspects:
Am at a loss as to what else to check. It is a consistent problem now that the tropical monsoon season is in force. At its current scale it doesn't seem to be causing problems but I don't want it to get worse and cause electrical problems.
I've only had the car (a '08 Mazda2 hatch) for a year or so and I've only started noticing this happening and I'm wondering if it's just subpar design of the cowl area to handle extremely heavy rain, or if something is definitely broken that I need fixed..
- cowl drains (scuttle drains) are clear
- windshield seal (original, never replaced) passes the soapy water/compressed air test all around
- no moisture around firewall grommets
- AC condensate drain tube is clear
- dumped a few buckets of water all over the windshield and cowl area with the hood down while washing my car- completely dry inside
- door seals dry, rest of footwell completely dry except for the exact spots where the drops of water came down onto it
