Might-Vac choices
NH
I'm looking through their website.
I would like a pneumatic one that uses compressor.
But I would like one that also dispenses fluids from it's
reservoir to a container. It seems only the hand pump operated
one (MV7201 Fluid Evacuator Plus) can do this. Does this sound
right?
Yes, MV7201 Fluid Evacuator Plus is the only one that can extract and dispense fluid. I had 1 for about 7 years and still working very well without making mess doing either extract fluid or dispense use fluid into a container.
Good think about hand pump extractor is it can be transported to anywhere and use it without compressor. Its pump is very easy to use, if you can pump a bicycle pump you can pump this extractor.
My MityVac hand pump has done okay for about 5 or so years that I have had it. As mentioned, no compressor.
The cheaper ones from HF I have heard to stay away from.
