Pretty cool idea - had an in line secondary filter that was basically a PTFE (teflon) puck that could scrub down to 2 microns.
The value proposition was change the filter every 10K and keep the sump for 30.
It worked, they landed a bunch of city contracts, then they cheapened the build and it fell apart.
They had a board of experienced filter people.
They refused to publish 4548-12, which led to cries of foul here, and ultimately it turns out 4548-12 isnt supposed to be used for under 10 microns or some threshold I cant remember.
Some of the best ISO particle counts we've seen from a spin on are from it, and there were long discussion about it here I was in a bunch of them. It both did what it was supposed to and failed at it simultaneously.
An original designer got an amazon (Norb Ascension sp?) and wrote up a review claiming the redesign killed the performance and shortly after the things folded. I think the deal is they tried to avoid paying the design team a royalty hence the redesign
A better executed example of 2 stage filter would be the cummins strata-pour venturi that uses stacked cardboard disks acting as the bypass vs the PTFE disk.
If some one reputable picked up the original microgreen design Id be a customer.
