JHZR2
Staff member
Hi
I am in need of some detailing advice. I have a 91 BMW that I purchased used. Most everywhere it looks great, with a straight body, no dents, and pretty clean paint. It has what I'd call microscratches in the paint finish though on a few different panels. The best description is that it looks almost like brushed aluminum that is used for trim in some high end cars and stuff.
The paint is original, and its what Id call a five or ten foot paint job. From that far away, you dont see the micro-lines, and it looks pretty good. From closer though, you can see these fine lines.
I don't know if the car has a clearcoat, and if it does, if the lines are due to the clearcoat or the paint. Id like to try to make them go away, so the paint looks smoother close up. I dont have the money right now to get a proper repainting of the car, so I hope to help it out a bit.
The only thing that Ive tried is 3m light cut compound. All my other cars have been purchased new and i keep good car eof the paint, so Ive never had to worry about this sort of thing. I may not have the audacity to try and fix it myself, besides on a small inconspicuous area. But I want to be as informaed as possible, and if I am confident, then I want to try and get the car to look really great.
Another issue is the presence of some 'blotches' on the paint. They are small spots, smaller than a dime, where the paint looks a little bit cloudy. There are very few of them, and it doesnt take away from the overall look of the car (probably because the car is silver), but I see them. I believe that they are the remnants of soem tree sap or similar substance being on the paint surface. I have tried using a clay bar to remove them, wth no luck. Light cut compound didnt do anything either. Old fashioned bug and tar remover doesnt help either. I am considering trying striaght rubbing alcohol to see if it can dissolve whatever is on the surface. However, it may have effected the paint. Any ideas?
Any comments or suggestions for fixing my paint wouldbe most appreciated. I dont have the tools to work on the car other than by hand. If it is reccomended that a mechanical item be used, Ill probably take it somewhere, but as I said, I want to be informed one way or another.
Many thanks,
JMH
Many thanks,
JMH
