Summer tires can be even better than all seasons in the rain.. depends on the tire.Rain
I have the Michelins and no complaints. I even didn’t put my snow tires on, and got away with it 2 seasons.Normally I'd just immediately go with the Michelin, but the Conti's on the truck have been excellent, so I'm considering them for the Jeep as well. The Pirelli run flats are pretty much at the wear bars, so contemplating pulling the trigger on replacements before the winter, but may hold off until the spring.
Size is 295/45ZR20
Conti:
Michelin:
Both tires have the same tread depth.
Conti's are UTQG 560 A A, 80,000km tread wear warranty
PSAS's are UTQG 540 AA A, 70,000km tread wear warranty
The Michelin's are made in the USA and weigh 33lbs each
The Conti's are made in Romania and weigh 36lbs each
Somewhat surprised at the weight difference!
Now, the specs on the tires they are replacing:
Pirelli P Zero Run Flat
UTQG 220 AA A (they lasted about 20,000km)
Weight: 43lbs each
Price is not a huge factor, they are within $180 of each other for a set of 4 at my dealership, so it's not a considerable gap like it was with the truck.
Thoughts?
Yup, the PSS were absolutely phenomenal in the wet.Summer tires can be even better than all seasons in the rain.. depends on the tire.
Similar experience here (Pilot A/S3+ vs DWS under consideration by OP). If the previous version of the Michelins is an indicator of the A/S4, I’d give the Michelin tire a slight edge overall.I have DWS 06+. Based on the performance of Michelin Pilot AS 3+ on Tiguan, I would go with Michelin compared to DWS. It is better rounded and while Conti does not fail in any discipline, on the contrary, has a ridiculous wet grip, two things bother me:
1. I can always feel tires on the steering wheel. They never balance as well as Michelin.
2. Soft sidewalls when doing some sharp cornering.
I have these too, and remind myself I can take the bridge on ramp much faster than most, what am I doing going so slowlyYup, the PSS were absolutely phenomenal in the wet.
The Conti's are 3lbs heavier than the Michelin.Continental without any question. Three pounds unsprung weight per corner savings. Seals the deal.
Misread that quite well. Michelin for the weight savings.The Conti's are 3lbs heavier than the Michelin.
Pifft the last summer tires you drove were Michelin Pilot Sports circa 2005. <jking>In my experience, all my summer tires were excellent in the rain. Certainly not any worse than all-seasons.
I'mma put on the latest Pilot Sports on my Crosstrek. LOL!Pifft the last summer tires you drove were Michelin Pilot Sports circa 2005. <jking>
?Rain
However, test does not tell you that DWS06 is very hard to balance and that Michelin generally always keep initial performance longer.https://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=280
I'm sure you've seen this comparison already. The DWS06+ seem like the better tire overall, with better NVH at the cost of some steering feel. 3 lbs heavier is not great but still much lighter than the RFTs
The tread is very similar to the Michelin F1 rain tire. That's why they are so great in the wet.Yup, the PSS were absolutely phenomenal in the wet.
my experience as well...I had both tires on my CTS4 Sport Wagon...I think I felt a touch more road feel with the Michelins but I felt they started to lose their grip around 35K miles...the DWS-06 Plus had a slightly more cushy ride, did everything else as well as the Michelin's but exceeded the Michelin's in the wet and the snow...Similar experience here (Pilot A/S3+ vs DWS under consideration by OP). If the previous version of the Michelins is an indicator of the A/S4, I’d give the Michelin tire a slight edge overall.
That said, the DWS is quieter and rides slightly better on my 2008 Audi A4 Avant. The A/S3+ is more communicative, and gives the “feel” of being is better control of the car in daily driving.
If the AS4 is improved over A/S3+ then it seems the better tire.
Can’t go wrong with either tire, however (IMHO).
