Michelin Harmony
SC
Had it not pulled to the left immediately before I had the new tires installed I would agree with you that the alignment is out of sinq?
I just purchased a set of P225/70R14 Michelin Harmony’s for my ’99 2wd Tacoma. I noticed the minute I pulled out of the lot that the truck was pulling to the left – at all speeds.
Could I have gotten a bad tire? Should I insist on having the retailer install another tire? Or, would rotating the front to the back correct the problem and then will it work itself out?
Sounds like the alignment is off.
BTW,I had Harmony's cure the pull problems on my Seinna.They sure are nice tires IHO.
Alan,
I thought about tire inflation, too. That was the first thing I checked and they're all equally inflated.
Maybe you just got one bum tire.I'd go back and disuss it with whomever you bought it from.
