Hello.
1991 Mercedes 300SE, 3.2 I6 with 195k miles on the clock.
I'm having trouble with Merc's emissions: CO is 0.45% (limit(0.30%) and HC around 200 (limit 100).
Basic parts have been changed ie. plugs, wires, ECM temperature sensor, O2 sensor, catalytic converters, distributor cap and rotor etc.
Now the car started to not react to gas pedal ie. it is reluctant to rev until you press pedal past halfway. Then it revs very freely. Also in freeway speeds ie. 3000 rpm it works like a dream.
Also, when I start it cold idle jumps up and down by say 300 rpm.
It was at the dealer and they could not see anything with Mercedes factory program.
Their opinion now is MAF - symptoms would point to that.
There is no coolant loss and oil remains clean. MPG is reasonable. There is no white, black or blue smoke cold or warm.
Any ideas?
Any ideas?
